PHOENIX Robotics Lifting Column
The PHOENIX Robotics lifting column delivers extended reach, innovative performance, and versatile functionality across multiple industries. It is particularly effective for robotic applications such as palletising and depalletising, where stability, load capacity, and safety are essential. With exceptionally low lateral deflection, the lifting column ensures precise motion and safe operation without compromising robot performance.
Pfaff-Silberblau´s lifting column is engineered specifically for dynamic robotic applications, offering exceptional stability, precision, speed, and high load capability.
Features
Load capacity: up to 130 kg
Speed: up to 170 mm/s
Maximum stability: minimal deflection at maximum height under lateral load
Plug & Play integration: automatic detection by the robot controller for seamless operation with the flex pendant
Enclosed, low‑maintenance design
Very high positioning and repeat accuracy
Duty cycle: 40% at maximum load and speed (higher duty cycles possible at reduced values)
Safety features: STO functionality
Plug&Play FANUC AddIn
Suitable Applications
  • Palletising, Depalletising
  • Material handling
  • Pick & place
  • bin picking
  • AMRs
  • Machine tending
  • Assembly
Quick Facts
Compatibilty with which CRX model:
CRX-3iA, CRX-5iA, CRX-10iA, CRX-20iA, (CRX-30iA – with dynamic movement limitations)
Includes CRX Plugin?
Yes
Ready to schedule a CRX Cobot demo or request a quote?
